Στοιχεία και φωτό από το ultimatemotorcycling.com
2021 BMW S 1000 R Specs
ENGINE
FRAME
COLORS:
ENGINE
- Type: Inline-4
- Displacement: 999cc
- Bore x stroke: 80 x 49.7mm
- Maximum power: 165 horsepower @ 11,000 rpm
- Maximum torque: 84 ft/lbs @ 9250 rpm
- Top speed: Over 155 mph
- Compression ratio: 12.5:1
- Fueling: 48mm throttle bodies
- Valvetrain: DOHC; 4vpc
- Transmission: 6-speed
- Clutch: Wet multiplate w/ assist-and-slipper functions
- Final drive: 525 chain
FRAME
- Type: Aluminum composite bridge w/ load-bearing engine
- Front suspension; travel: Fully adjustable 45mm inverted fork; 4.7 inches
- Rear suspension; travel: Linkage-assisted fully adjustable shock; 4.6 inches
- Wheels: Aluminum die-cast
- Front wheel: 3.50 x 17
- Rear wheel: 6.00 x 17
- Front tire: 120/70 x 17
- Rear tire: 190/55 x 17
- Front brakes: 320mm floating discs w/ 4-piston fixed Hayes calipers
- Rear brake: 220mm disc w/ single-piston floating Brembo caliper
- ABS: BMW ABS Pro
- Wheelbase: 57.1 inches
- Rake: 24 degrees
- Trail: 3.8 inches
- Seat height: Adjustable: 31.9, 32.3, or 32.7 inches
- Fuel capacity: 4.4 gallons
- Estimate fuel consumption: 38 mpg
- Curb weight: 438 pounds
COLORS:
- Black Strom Metallic
- San Marino Blue (+$200)
- Motosport (HP Style Package only, +$500)
